Einleitung
The Samsung Odyssey NP800G5M memory cards are integral to how the laptop functions to store temporary data such as RAM (Random Access Memory) and permanent information such as ROM (Read-Only Memory). Use this guide to replace the RAM in your device.
Was du brauchst
Remove the three 6.6 mm screws on the back of the computer using the Phillips #0 screwdriver.
Insert the spudger in one of the top notches of the window and work your way to the other side until you achieve complete separation of the panel.
Using your hands, spread the locking mechanism apart to free the RAM.
Remove the RAM from the device.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
