Einleitung
In the instance of a broken screen, many laptop users will consider their device useless and begin looking for an entirely new laptop. However, this issue can be remedied in a more cost effective way by installing a new screen to the laptop, which can be a quick and simple process if done correctly.
To ensure an efficient screen replacement of the Samsung Odyssey NP800G5M, use the steps listed in the following guide.
Was du brauchst
Remove the eleven 6.6 mm screws on the back of the computer using the Phillips #0 screwdriver.
Using the opening tool, gently pry apart the back corners until the plastic separates from the body of the laptop.
Work your way around the body of the laptop until the back cover is completely separated.
Remove the back casing.
Remove the four 6.6 mm screws using the Phillips #0 screwdriver.
Remove the battery from the device.
Take the flat end of spudger and flip up the LCD wire connection locking mechanism.
Remove the LCD wire connection by pulling up on the tab until the cable is free.
Take the spudger and carefully wedge it in between the screen casing and bezel.
Continue working the bezel around the edge of the screen until the bezel separates from the screen.
Using the Phillips #0 Screwdriver, remove the four screws holding the screen in place.
Turn the device over (right side up) and let the screen lie face down on the keyboard.
Remove the LCD LVDS cable.
Using the spudger, lift the brown lock up.
Pull the brown lock away from you until the mechanism separates.
Remove the screen from the device.
5 weitere Personen haben diese Anleitung absolviert.
