Zum Hauptinhalt wechseln
Samsung Odyssey NP800G5M Speaker Replacement
Was du brauchst
  1. Samsung Odyssey NP800G5M Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the eleven 6.6 mm screws on the back of the computer using the Phillips #0 screwdriver.
  2. Samsung Odyssey NP800G5M Speaker Replacement: Schritt 2, Bild 1 von 2 Samsung Odyssey NP800G5M Speaker Replacement: Schritt 2, Bild 2 von 2
    • Using the opening tool, gently pry apart the back corners until the plastic separates from the body of the laptop.
    • Work your way around the body of the laptop until the back cover is completely separated.
    • Remove the back casing.
  3. Samsung Odyssey NP800G5M Speaker Replacement: Schritt 3, Bild 1 von 2 Samsung Odyssey NP800G5M Speaker Replacement: Schritt 3, Bild 2 von 2
    • Disconnect the battery connector cable.
    • Working on the device without removing the battery connector cable can damage major components of the device.
  4. Samsung Odyssey NP800G5M Speaker Replacement: Schritt 4, Bild 1 von 3 Samsung Odyssey NP800G5M Speaker Replacement: Schritt 4, Bild 2 von 3 Samsung Odyssey NP800G5M Speaker Replacement: Schritt 4, Bild 3 von 3
    • Remove the four 6.6 mm screws using the Phillips #0 screwdriver.
    • Remove the battery from the device.
  5. Samsung Odyssey NP800G5M Speaker Replacement, Speaker: Schritt 5, Bild 1 von 3 Samsung Odyssey NP800G5M Speaker Replacement, Speaker: Schritt 5, Bild 2 von 3 Samsung Odyssey NP800G5M Speaker Replacement, Speaker: Schritt 5, Bild 3 von 3
    • Using the spudger, lift the black tab to release the ribbon cable.
    • Disconnect the USB ribbon cable.
  6. Samsung Odyssey NP800G5M Speaker Replacement: Schritt 6, Bild 1 von 2 Samsung Odyssey NP800G5M Speaker Replacement: Schritt 6, Bild 2 von 2
    • Remove the tape securing the wire down.
    • This tape will remain sticky after removal.
  7. Samsung Odyssey NP800G5M Speaker Replacement: Schritt 7, Bild 1 von 2 Samsung Odyssey NP800G5M Speaker Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the speakers by pulling the plugs out of their sockets.
  8. Samsung Odyssey NP800G5M Speaker Replacement: Schritt 8, Bild 1 von 3 Samsung Odyssey NP800G5M Speaker Replacement: Schritt 8, Bild 2 von 3 Samsung Odyssey NP800G5M Speaker Replacement: Schritt 8, Bild 3 von 3
    • Using the Phillips #0 screwdriver, remove the four screws holding the speakers to device.
    • Remove the speakers from the device.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 416
