Einleitung
Built -in speakers are one of the benefits of owning a laptop, so any malfunctioning or broken speakers are an inconvenience to laptop users. Rather than purchasing external speakers or wearing headphones whenever audio is needed, this issue can be remedied in a more cost effective way by installing a new speaker into the laptop. This guide will show you how to replace the speakers in your laptop.
Was du brauchst
Remove the eleven 6.6 mm screws on the back of the computer using the Phillips #0 screwdriver.
Using the opening tool, gently pry apart the back corners until the plastic separates from the body of the laptop.
Work your way around the body of the laptop until the back cover is completely separated.
Remove the back casing.
Remove the four 6.6 mm screws using the Phillips #0 screwdriver.
Remove the battery from the device.
Using the spudger, lift the black tab to release the ribbon cable.
Disconnect the USB ribbon cable.
Using the Phillips #0 screwdriver, remove the four screws holding the speakers to device.
Remove the speakers from the device.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
