Einleitung
This is a simple replacement, requiring no tools.
Flip Samsung PL200 over to access battery/SD card compartment on the bottom. There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/SD card compartment door. Once opened, the battery should be visible.
Once the battery/SD card compartment is opened, in order to remove the battery, you must push the small blue release button.
This will release the spring loaded battery.
Use your fingers to remove the old battery.
Insert the new battery into the battery slot.
Push it down with your finger until the blue release switch re-engages over top of the battery.
Close the battery/SD card compartment.
After replacing the battery, be sure to connect your charger cable and charge the new battery fully before using it.
2 Kommentare
Is the battery dead? Can Samsung indicate wher new batteries are sold? Camera retailers are rare, these days
No-one can find a contact address for Samsung spares. New smartphones, no problem! Thank you for trying. I just have to keep looking! Reg
