Zum Hauptinhalt wechseln
Samsung Propel Motherboard Replacement
Was du brauchst
  1. Samsung Propel Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the back panel of the phone.
  2. Samsung Propel Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the old battery and replace with the new one.
  3. Samsung Propel Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Use a flat-head screwdriver to remove the back lid.
  4. Samsung Propel Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Locate the six screws and remove them with a Phillips #00 Screwdriver.
    • Insert the flat-head screwdriver into the crevice.
    • Slide and dislodge the snap-ons that are beneath the crevice.
    • Remove the back frame of the device.
  5. Samsung Propel Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Locate and remove the six screws with a Phillips #00 Screwdriver.
    • Separate the black middle frame from the front frame.
    • Be careful not to tear the phone bus.
  6. Samsung Propel Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Locate and remove the four screws with a Phillips #00 Screwdriver.
    • Slide the flat-head screwdriver and dislodge the snap-ons beneath the crevice.
    • Be careful not to rip the band.
  7. Samsung Propel Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Use your hands to remove both the phone buses from the linkages and remove the motherboard.
Abschluss
Minh
201 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 1-3, Nelson Spring 2011 Mitglied von CSU Los Angeles, Team 1-3, Nelson Spring 2011
CSULA-NELSON-S11S1G3
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,767
