Einleitung
Use this guide to remove and replace the Samsung Propel screen.
Was du brauchst
Press down the back and push up to remove back cover.
Insert finger into gap at the top left and remove battery.
Insert the flat-head screwdriver into the crevice.
Slide and dislodge the snap-ons that are beneath the crevice.
Remove the back frame of the device.
Locate and remove the six screws with a Phillips #00 Screwdriver.
Separate the black middle frame from the front frame.
Slide the flat-head screwdriver and dislodge the snap-ons beneath the crevice.
Use your hands to remove both the phone buses from the linkages and remove the motherboard.
Flip and pull eletric band from input.
Remove the screen from the front frame.
