Einleitung
Replacing your water filter is a necessity to ensure you have clean water. This guide will direct you on how to replace the water filter in a Samsung RH9000H FSR Foodshowcase 765 L refrigerator. The only part you would need is a HAF-CIN water filter. Once the red filter symbol is gone, you will know that the replacement is complete. It is required to change the water filter every six months.
Was du brauchst
Open the refrigerator door and locate the filter at the bottom right corner of the fridge.
Insert the new filter in place of the old one.
Twist the handle clockwise to lock it into place at the "Lock" position.
Turn on the water supply for the fridge.
Dispense up to 4 gallons of water to get rid of any impurities in the water.
