Zum Hauptinhalt wechseln
Samsung Water Filter (Horizontal Filter) Replacement
Was du brauchst
  1. Samsung Water Filter (Horizontal Filter) Replacement, Open the refrigerator doors: Schritt 1, Bild 1 von 2 Samsung Water Filter (Horizontal Filter) Replacement, Open the refrigerator doors: Schritt 1, Bild 2 von 2
    • Open both French doors for the refrigerator compartment.
  2. Samsung Water Filter (Horizontal Filter) Replacement, Locate the water filter: Schritt 2, Bild 1 von 2 Samsung Water Filter (Horizontal Filter) Replacement, Locate the water filter: Schritt 2, Bild 2 von 2
    • Locate the water filter.
    • On this model, the filter can be found at the bottom of the main compartment, between the crisper drawers.
  3. Samsung Water Filter (Horizontal Filter) Replacement, Remove the filter: Schritt 3, Bild 1 von 2 Samsung Water Filter (Horizontal Filter) Replacement, Remove the filter: Schritt 3, Bild 2 von 2
    • Twist the water filter cap counter-clockwise until it's loosened from its housing.
  4. Samsung Water Filter (Horizontal Filter) Replacement: Schritt 4, Bild 1 von 2 Samsung Water Filter (Horizontal Filter) Replacement: Schritt 4, Bild 2 von 2
    • Pull the water filter straight out of its housing and remove it.
    • When you install the replacement filter, remember to remove the cap on the new filter.
  5. Samsung Water Filter (Horizontal Filter) Replacement: Schritt 5, Bild 1 von 2 Samsung Water Filter (Horizontal Filter) Replacement: Schritt 5, Bild 2 von 2
    • Run the water to flush the filter and check for leaks for a few minutes.
    • Press reset on the filter indicator.
Abschluss
nicO
15.927 Reputation
88 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
33 Mitglieder
555 Anleitungen geschrieben
2 Kommentare
IS there a difference from the HAF-QIN and the HAF-QIN/EXP
bigjon7379 - Antwort
Does anyone have instructions on taking out the filter assembly to find where leaks are coming from?
Larry - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 29
Letzte 30 Tage: 119
Insgesamt: 15,384
