Einleitung
There could be many reasons the Bluetooth module on the device will not connect, such as water damage or electric shock. This guide will show you step by step how to replace a non-functioning Bluetooth Module. In order to start working on your device, you will need to prepare a clean, dry, and flat work space. It is recommended to have a place to store screws during the process.
Was du brauchst
Use the plastic opening tool to lift and remove the rubber grommet plugs.
Using a PH1 Philips screwdriver, remove four (9.5mm x 1.6mm) screws from the base plate.
Remove base plate by stabilizing speaker and using plastic prying tool to pry the base plate from the speaker.
Place the speaker on the table with the Touch Pad facing down. This will leave you with the Port Panel exposed.
Remove speaker grill by stabilizing speaker on a table and applying pressure to the bottom of the speaker. Slide the speaker grill up and away from the remaining endcap.
Remove the two exposed (9.5mm x 1.6mm) PH1 Phillips screws on the Port Panel.
Remove the Port Panel from the speaker body, exposing the ribbon cables.
While stabilizing the Port Panel remove the two ribbon cables one at a time by pressing the locking clip down on the ribbon cable connectors and pulling the connector away from the Port Panel.
Remove the four (9.5mm x 1.6mm) PH1 Phillips screws on the port speaker body.
Remove the Port Panel exposing the subwoofer.
Remove the eight (9.5mm x 1.6mm) PH1 Phillips screws on the right side of the speaker body.
Remove the one (9.5mm x 1.6mm) PH1 Phillips screw on the left side of the speaker body.
Remove the ribbon cable from the tweeter which is attached to the main motherboard.
Slide the tweeter out of the enclosure.
Disconnect white connector by pushing down on the release tab while gently pulling the connector free from the socket.
Remove wiring harness and set aside.
Locate and remove the two PH2 Phillips screws from the base of the motherboard assembly.
Flip the motherboard assembly over and locate the Bluetooth module on the side of the metal frame.
Remove the one PH2 Philips screw.
Press the white tab while gently pulling the Bluetooth module away from the connector and frame.
4 Kommentare
Nice write up, but where does one obtain a new Bluetooth module for one of these?
Bluetooth module model is WIBT30D. You can google for it. It cost ~30 euro now
You all seem to know your way around these devices. Do you think it's possible to create an 'aux' style connection to allow wired playback? If WiFi and Bluetooth are failing, having the ability to connect to connect via wire would be really good.
