Zum Hauptinhalt wechseln
Samsung Radiant 360 R1 Micro USB / Power Port Panel Replacement
Was du brauchst
  1. Samsung Radiant 360 R1 Micro USB / Power Port Panel  Replacement, Micro USB / Power Port Panel: Schritt 1, Bild 1 von 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Use the plastic opening tool to lift and remove the rubber grommet plugs.
  2. Samsung Radiant 360 R1 Micro USB / Power Port Panel  Replacement: Schritt 2, Bild 1 von 1
    • Using a PH1 Philips screwdriver, remove four (9.5mm x 1.6mm) screws from the base plate.
    • Remove base plate by stabilizing speaker and using plastic prying tool to pry the base plate from the speaker.
  3. Samsung Radiant 360 R1 Micro USB / Power Port Panel  Replacement: Schritt 3, Bild 1 von 1
    • Place the speaker on the table with the Touch Pad facing down. This will leave you with the Port Panel exposed.
    • Remove speaker grill by stabilizing speaker on a table and applying pressure to the bottom of the speaker. Slide the speaker grill up and away from the remaining endcap.
  4. Samsung Radiant 360 R1 Micro USB / Power Port Panel  Replacement: Schritt 4, Bild 1 von 1
    • Remove the two exposed (9.5mm x 1.6mm) PH1 Phillips screws on the Port Panel.
    • Remove the Port Panel from the speaker body, exposing the ribbon cables.
  5. Samsung Radiant 360 R1 Micro USB / Power Port Panel  Replacement: Schritt 5, Bild 1 von 1
    • While stabilizing the Port Panel remove the two ribbon cables one at a time by pressing the locking clip down on the ribbon cable connectors and pulling the connector away from the Port Panel.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UW Tacoma, Team 2-5, Rose Winter 2017 Mitglied von UW Tacoma, Team 2-5, Rose Winter 2017
UWT-ROSE-W17S2G5
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 928
