Zum Hauptinhalt wechseln
Samsung Radiant 360 R1 Motherboard Replacement
Was du brauchst
  1. Samsung Radiant 360 R1 Motherboard Replacement, Micro USB / Power Port Panel: Schritt 1, Bild 1 von 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Use the plastic opening tool to lift and remove the rubber grommet plugs.
  2. Samsung Radiant 360 R1 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Using a PH1 Philips screwdriver, remove four (9.5mm x 1.6mm) screws from the base plate.
    • Remove base plate by stabilizing speaker and using plastic prying tool to pry the base plate from the speaker.
  3. Samsung Radiant 360 R1 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Place the speaker on the table with the Touch Pad facing down. This will leave you with the Port Panel exposed.
    • Remove speaker grill by stabilizing speaker on a table and applying pressure to the bottom of the speaker. Slide the speaker grill up and away from the remaining endcap.
  4. Samsung Radiant 360 R1 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the two exposed (9.5mm x 1.6mm) PH1 Phillips screws on the Port Panel.
    • Remove the Port Panel from the speaker body, exposing the ribbon cables.
  5. Samsung Radiant 360 R1 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • While stabilizing the Port Panel remove the two ribbon cables one at a time by pressing the locking clip down on the ribbon cable connectors and pulling the connector away from the Port Panel.
  6. Samsung Radiant 360 R1 Motherboard Replacement, 1" Tweeter Speaker: Schritt 6, Bild 1 von 3 Samsung Radiant 360 R1 Motherboard Replacement, 1" Tweeter Speaker: Schritt 6, Bild 2 von 3 Samsung Radiant 360 R1 Motherboard Replacement, 1" Tweeter Speaker: Schritt 6, Bild 3 von 3
    • Remove the four (9.5mm x 1.6mm) PH1 Phillips screws on the port speaker body.
    • Remove the Port Panel exposing the subwoofer.
  7. Samsung Radiant 360 R1 Motherboard Replacement: Schritt 7, Bild 1 von 3 Samsung Radiant 360 R1 Motherboard Replacement: Schritt 7, Bild 2 von 3 Samsung Radiant 360 R1 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Remove the eight (9.5mm x 1.6mm) PH1 Phillips screws on the right side of the speaker body.
    • Remove the one (9.5mm x 1.6mm) PH1 Phillips screw on the left side of the speaker body.
    • The body sides are denoted with a "R" and an "L" for right and left sides.
  8. Samsung Radiant 360 R1 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Open up the body to expose the inner panel and motherboard.
  9. Samsung Radiant 360 R1 Motherboard Replacement: Schritt 9, Bild 1 von 3 Samsung Radiant 360 R1 Motherboard Replacement: Schritt 9, Bild 2 von 3 Samsung Radiant 360 R1 Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Remove the ribbon cable from the tweeter which is attached to the main motherboard.
    • Slide the tweeter out of the enclosure.
  10. Samsung Radiant 360 R1 Motherboard Replacement, Bluetooth Module: Schritt 10, Bild 1 von 1
    • Slide rubber grommet out of slot on plastic housing.
    • This may have occurred naturally when separating the two halves.
  11. Samsung Radiant 360 R1 Motherboard Replacement: Schritt 11, Bild 1 von 3 Samsung Radiant 360 R1 Motherboard Replacement: Schritt 11, Bild 2 von 3 Samsung Radiant 360 R1 Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Disconnect white connector by pushing down on the release tab while gently pulling the connector free from the socket.
    • Remove wiring harness and set aside.
    • The other connectors in the wiring harness should already be free from previous steps.
  12. Samsung Radiant 360 R1 Motherboard Replacement: Schritt 12, Bild 1 von 2 Samsung Radiant 360 R1 Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Locate and remove the two PH2 Phillips screws from the base of the motherboard assembly.
    • These screws may be extremely tight. Be careful not to snap the plastic when removing the screws.
  13. Samsung Radiant 360 R1 Motherboard Replacement: Schritt 13, Bild 1 von 2 Samsung Radiant 360 R1 Motherboard Replacement: Schritt 13, Bild 2 von 2
    • Flip the motherboard assembly over and locate the Bluetooth module on the side of the metal frame.
    • Remove the one PH2 Philips screw.
  14. Samsung Radiant 360 R1 Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Press the white tab while gently pulling the Bluetooth module away from the connector and frame.
  15. Samsung Radiant 360 R1 Motherboard Replacement, Motherboard: Schritt 15, Bild 1 von 3 Samsung Radiant 360 R1 Motherboard Replacement, Motherboard: Schritt 15, Bild 2 von 3 Samsung Radiant 360 R1 Motherboard Replacement, Motherboard: Schritt 15, Bild 3 von 3
    • Pinch the release tab on the remaining small white connector to disconnect the final wiring harness from the motherboard.
  16. Samsung Radiant 360 R1 Motherboard Replacement: Schritt 16, Bild 1 von 2 Samsung Radiant 360 R1 Motherboard Replacement: Schritt 16, Bild 2 von 2
    • Remove the four PH2 Phillips screws holding the motherboard to the mounting frame.
    • Carefully separate the motherboard from the metal frame.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Aaron Bristow
406 Reputation
3 Anleitungen geschrieben
Washington State, Team S5-G121, Phelps-Hillen Fall 2017 Mitglied von Washington State, Team S5-G121, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S5G121
4 Mitglieder
Ein Kommentar
About to change my motherboard on R5. Do you need a software afterwards?
Marques - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 704
