Zum Hauptinhalt wechseln
Samsung Radiant360 R3 Wireless Module Replacement
Was du brauchst
  1. Samsung Radiant360 R3 Wireless Module Replacement, Wireless Setup Button and USB Module: Schritt 1, Bild 1 von 3 Samsung Radiant360 R3 Wireless Module Replacement, Wireless Setup Button and USB Module: Schritt 1, Bild 2 von 3 Samsung Radiant360 R3 Wireless Module Replacement, Wireless Setup Button and USB Module: Schritt 1, Bild 3 von 3
    • Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
    • Remove the four 10mm long screws with the Phillips #1 screwdriver.
  2. Samsung Radiant360 R3 Wireless Module Replacement: Schritt 2, Bild 1 von 1
    • Remove the bottom shell from the speaker.
  3. Samsung Radiant360 R3 Wireless Module Replacement: Schritt 3, Bild 1 von 2 Samsung Radiant360 R3 Wireless Module Replacement: Schritt 3, Bild 2 von 2
    • Remove the connector from the board by pressing down on the center tab while nudging the connector away with a spudger.
    • Be careful not to pull directly on the wires or apply too much pressure, or you risk breaking the connector.
  4. Samsung Radiant360 R3 Wireless Module Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 10mm long screws from the board utilizing the Phillips #1 screwdriver.
  5. Samsung Radiant360 R3 Wireless Module Replacement: Schritt 5, Bild 1 von 1
    • Use a spudger to press the plastic tab away from the board until the board pops up.
    • Remove the board with the USB module from the device.
  6. Samsung Radiant360 R3 Wireless Module Replacement, Wireless Module: Schritt 6, Bild 1 von 2 Samsung Radiant360 R3 Wireless Module Replacement, Wireless Module: Schritt 6, Bild 2 von 2
    • Remove the two 12mm long screws with the Phillips #1 screwdriver.
    • Unplug white plug connected to the green circuit board.
  7. Samsung Radiant360 R3 Wireless Module Replacement: Schritt 7, Bild 1 von 2 Samsung Radiant360 R3 Wireless Module Replacement: Schritt 7, Bild 2 von 2
    • Remove the four 12mm long screws with the Phillips #1 screwdriver.
    • Remove the cover, and slide the cord through the hole.
  8. Samsung Radiant360 R3 Wireless Module Replacement: Schritt 8, Bild 1 von 3 Samsung Radiant360 R3 Wireless Module Replacement: Schritt 8, Bild 2 von 3 Samsung Radiant360 R3 Wireless Module Replacement: Schritt 8, Bild 3 von 3
    • Remove rubber covers covering the screws with pair of tweezers.
    • Remove the six 12mm screws that are under the rubber covers with the Phillips #1 screwdriver.
  9. Samsung Radiant360 R3 Wireless Module Replacement: Schritt 9, Bild 1 von 1
    • Remove the unscrewed cover as much as possible.
    • It is very difficult to get plugs at the end of the cord through the cover without breaking, so just slide to the edge.
  10. Samsung Radiant360 R3 Wireless Module Replacement: Schritt 10, Bild 1 von 3 Samsung Radiant360 R3 Wireless Module Replacement: Schritt 10, Bild 2 von 3 Samsung Radiant360 R3 Wireless Module Replacement: Schritt 10, Bild 3 von 3
    • Push the body out through the outer shell of device.
    • Carefully push the ring attached to the cable through the shell.
  11. Samsung Radiant360 R3 Wireless Module Replacement: Schritt 11, Bild 1 von 3 Samsung Radiant360 R3 Wireless Module Replacement: Schritt 11, Bild 2 von 3 Samsung Radiant360 R3 Wireless Module Replacement: Schritt 11, Bild 3 von 3
    • Remove the eight 12mm long screws around the body with the Phillips #1 screwdriver.
  12. Samsung Radiant360 R3 Wireless Module Replacement: Schritt 12, Bild 1 von 2 Samsung Radiant360 R3 Wireless Module Replacement: Schritt 12, Bild 2 von 2
    • Pry the two halves of the body open using a metal spudger.
  13. Samsung Radiant360 R3 Wireless Module Replacement: Schritt 13, Bild 1 von 3 Samsung Radiant360 R3 Wireless Module Replacement: Schritt 13, Bild 2 von 3 Samsung Radiant360 R3 Wireless Module Replacement: Schritt 13, Bild 3 von 3
    • Remove the plugs located topmost right and closest to the bottom in picture.
  14. Samsung Radiant360 R3 Wireless Module Replacement: Schritt 14, Bild 1 von 1
    • Remove the four 12mm long screws with the Phillips #1 screwdriver .
  15. Samsung Radiant360 R3 Wireless Module Replacement: Schritt 15, Bild 1 von 1
    • Unscrew the four 8mm screws on the side of the motherboard with the Phillips #1 screwdriver .
    • Remove the Wireless Module from the device.
Abschluss
Fadi Alzammar
782 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S25-G18, Maness Spring 2018 Mitglied von Cal Poly, Team S25-G18, Maness Spring 2018
CPSU-MANESS-S18S25G18
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 270
