Einleitung
In this guide, we will be replacing the USB module of the speaker, which also houses the button used in pairing the speaker for Wi-Fi capabilities. You will need to remove the bottom cover, unplug the connector from the motherboard to it, and remove it from the speaker assembly.
Was du brauchst
Remove the connector from the board by pressing down on the center tab while nudging the connector away with a spudger.
Remove the two 10mm long screws from the board utilizing the Phillips #1 screwdriver.
Use a spudger to press the plastic tab away from the board until the board pops up.
Remove the board with the USB module from the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
