Zum Hauptinhalt wechseln
Samsung Rant Rear Case Replacement
Was du brauchst
  1. Samsung Rant Rear Case Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Turn the phone over in the palm of your hand, with the screen facing down.
    • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
    • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
    • You should now be able to lift the plate completely off of the phone.
  2. Samsung Rant Rear Case Replacement, Rear Case: Schritt 2, Bild 1 von 1
    • Use a Phillips #00 screwdriver to loosen and remove all 3 screws.
  3. Samsung Rant Rear Case Replacement: Schritt 3, Bild 1 von 1
    • Gently separate the rear case from the front case.
Abschluss
Denise Cooper
31 Reputation
3 Anleitungen geschrieben
James Madison, Team 1-6, Allen Fall 2011 Mitglied von James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 1,142
