Einleitung
This guide will provide a step-by-step procedure for replacing the front function keys on your Samsung Rogue.
Was du brauchst
With your thumbs, push down on the back cover of your phone and slide it away from the camera.
Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
Remove the five 3.0mm Philips screws around the outside of the sliding mechanisms.
Use tweezers to open the two black gates by putting them in the "up" position.
With the same tweezers, carefully pull out the orange strips from the two specified gates.
Using tweezers, gently remove the bottom orange strip from the device.
At this point you can easily lift out the rubber function key pad as well.
There are two ways you can take out the front function keys:
1) Use a plastic phone opening tool to pry out the piece from the front of the phone.
2) Simply pop out the piece from the inside by pushing on its tabs.
