Zum Hauptinhalt wechseln
Samsung Rogue Speaker/Antenna Replacement
Was du brauchst
  1. Samsung Rogue Speaker/Antenna Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung Rogue Speaker/Antenna Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
  2. Samsung Rogue Speaker/Antenna Replacement: Schritt 2, Bild 1 von 2 Samsung Rogue Speaker/Antenna Replacement: Schritt 2, Bild 2 von 2
    • You can now remove the battery by prying it up with your finger.
  3. Samsung Rogue Speaker/Antenna Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
  4. Samsung Rogue Speaker/Antenna Replacement: Schritt 4, Bild 1 von 1
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
  5. Samsung Rogue Speaker/Antenna Replacement: Schritt 5, Bild 1 von 3 Samsung Rogue Speaker/Antenna Replacement: Schritt 5, Bild 2 von 3 Samsung Rogue Speaker/Antenna Replacement: Schritt 5, Bild 3 von 3
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
  6. Samsung Rogue Speaker/Antenna Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 3.45 mm Philips screws below the white sticker.
  7. Samsung Rogue Speaker/Antenna Replacement: Schritt 7, Bild 1 von 2 Samsung Rogue Speaker/Antenna Replacement: Schritt 7, Bild 2 von 2
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
  8. Samsung Rogue Speaker/Antenna Replacement: Schritt 8, Bild 1 von 2 Samsung Rogue Speaker/Antenna Replacement: Schritt 8, Bild 2 von 2
    • Use a plastic opening tool to disconnect the film from the motherboard.
  9. Samsung Rogue Speaker/Antenna Replacement, Speaker/Antenna: Schritt 9, Bild 1 von 1
    • On the underside of the motherboard, remove the single 3.3mm Philips screw.
  10. Samsung Rogue Speaker/Antenna Replacement: Schritt 10, Bild 1 von 3 Samsung Rogue Speaker/Antenna Replacement: Schritt 10, Bild 2 von 3 Samsung Rogue Speaker/Antenna Replacement: Schritt 10, Bild 3 von 3
    • The speaker and the antenna are both connected on the same black piece.
    • Use a plastic opening tool to pop off the edges of the speaker/antenna piece from the motherboard.
    • Turn over the motherboard and carefully lift the speaker/antenna piece straight up.
    • The camera is held in the middle of the speaker/antenna piece. Make sure to lift directly up when lifting the speaker/antenna piece, otherwise you can risk damaging the camera.
Abschluss
Cal Poly, Team 7-32, Maness Spring 2012 Mitglied von Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 355
