Zum Hauptinhalt wechseln
Samsung S760 Camera Lens Replacement Guide
Was du brauchst
  1. Samsung S760 Camera Lens Replacement Guide, Battery: Schritt 1, Bild 1 von 3 Samsung S760 Camera Lens Replacement Guide, Battery: Schritt 1, Bild 2 von 3 Samsung S760 Camera Lens Replacement Guide, Battery: Schritt 1, Bild 3 von 3
    • Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
  2. Samsung S760 Camera Lens Replacement Guide: Schritt 2, Bild 1 von 2 Samsung S760 Camera Lens Replacement Guide: Schritt 2, Bild 2 von 2
    • Tip the camera as to gently slide the batteries out of the camera.
  3. Samsung S760 Camera Lens Replacement Guide, Front and Back Case: Schritt 3, Bild 1 von 3 Samsung S760 Camera Lens Replacement Guide, Front and Back Case: Schritt 3, Bild 2 von 3 Samsung S760 Camera Lens Replacement Guide, Front and Back Case: Schritt 3, Bild 3 von 3
    • All screws in this camera are removed using the Phillip Screwdriver #000 bit. Also, all dimensions included refer to screw lengths.
    • Locate and remove the six 4mm screws on the sides of the camera.
  4. Samsung S760 Camera Lens Replacement Guide: Schritt 4, Bild 1 von 2 Samsung S760 Camera Lens Replacement Guide: Schritt 4, Bild 2 von 2
    • Use the plastic opening tool to pry open the back case, following alongside the edge of the case if need be.
  5. Samsung S760 Camera Lens Replacement Guide: Schritt 5, Bild 1 von 1
    • Once the back case is removed, use the plastic opening tool to gently pry off the front case.
  6. Samsung S760 Camera Lens Replacement Guide, Camera Lens: Schritt 6, Bild 1 von 1
    • Move the screen down, out of the way to remove the two 3mm screws beneath it.
  7. Samsung S760 Camera Lens Replacement Guide: Schritt 7, Bild 1 von 2 Samsung S760 Camera Lens Replacement Guide: Schritt 7, Bild 2 von 2
    • Remove the 6mm screw labeled in the picture.
    • Remove the three 3mm screws.
    • Then proceed to flip the screen to the other side to remove the other 6mm screw.
  8. Samsung S760 Camera Lens Replacement Guide: Schritt 8, Bild 1 von 1
    • Proceed to carefully pull the ribbon cable out by using the little circular tabs sticking out on either side.
  9. Samsung S760 Camera Lens Replacement Guide: Schritt 9, Bild 1 von 2 Samsung S760 Camera Lens Replacement Guide: Schritt 9, Bild 2 von 2
    • Proceed to slowly pry off the mother board with the plastic opening tool by removing it at the micro USB attachment.
    • Then carefully manually pry off the golden colored section near the camera wheel until all of it is off.
  10. Samsung S760 Camera Lens Replacement Guide: Schritt 10, Bild 1 von 2 Samsung S760 Camera Lens Replacement Guide: Schritt 10, Bild 2 von 2
    • Finally, remove the final 3mm screw marked in the picture.
    • Lift the camera lens out of the lens compartment.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team S8-G1, Catania Spring 2017 Mitglied von UMass Dartmouth, Team S8-G1, Catania Spring 2017
UMASSD-CATANIA-S17S8G1
3 Mitglieder
11 Anleitungen geschrieben
2 Kommentare
Brilliantly explained. Makes it look so easy… even a fool such as I could follow the instructions.
frankasensale - Antwort
the guide is actually beautiful im just upset that mine got corroded from battery leakage and rusted the capacitors next to the charging port and caused it to fall off :c
AboynamedJason - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 13
Letzte 30 Tage: 39
Insgesamt: 1,254
