Einleitung
How to remove the front and back cases of the device
Was du brauchst
Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
Locate and remove the six 4mm screws on the sides of the camera.
Use the plastic opening tool to pry open the back case, following alongside the edge of the case if need be.
Once the back case is removed, use the plastic opening tool to gently pry off the front case.
This will be used as a prerequisite to other guides. To reassemble your device, follow these instructions in reverse order.
3 weitere Personen haben diese Anleitung absolviert.
