Zum Hauptinhalt wechseln
Samsung S860 LCD Screen Replacement
Was du brauchst
  1. Samsung S860 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 2 Samsung S860 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 2 von 2
    • Remove all screws along the edges of the camera, using a #00 Phillips screwdriver.
  2. Samsung S860 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Slide open the battery compartment cover before removing the exterior covers of the camera.
  3. Samsung S860 LCD Screen Replacement: Schritt 3, Bild 1 von 3 Samsung S860 LCD Screen Replacement: Schritt 3, Bild 2 von 3 Samsung S860 LCD Screen Replacement: Schritt 3, Bild 3 von 3
    • Carefully pull the back case (the side showing the LCD screen) away from the front half.
    • There are clips securing the top of the back case. Do not be afraid to use the proper amount of force to remove the back case.
    • Turn the camera around to the front (the lens side). Carefully remove the front case.
    • There are also clips on the lens' side as well, so do not be afraid to use force.
  4. Samsung S860 LCD Screen Replacement: Schritt 4, Bild 1 von 2 Samsung S860 LCD Screen Replacement: Schritt 4, Bild 2 von 2
    • Position the camera so the LCD screen is facing you.
    • Remove the LCD screen from the screen plate.
    • Replace the broken LCD screen with the functioning LCD screen.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 33-72, Johann Spring 2010 Mitglied von Cal Poly, Team 33-72, Johann Spring 2010
CPSU-JOHANN-S10S33G72
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 33
Insgesamt: 8,871
