Ersatzteile
Kein Ersatzteil erforderlich.
  1. Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb. Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb.
    • Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb.
  2. Slide battery toward bottom of the phone, ~1/4 inch, to clear the hooks that keep it secured to the back of the phone.
    • Slide battery toward bottom of the phone, ~1/4 inch, to clear the hooks that keep it secured to the back of the phone.
  3. Lift battery away from phone case.
    • Lift battery away from phone case.
    • The battery is now removed from the device. Congratulations.
  4. Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone. Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone.
    • Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone.
  5. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  6. When unscrewed, pull the antenna straight up and out.
    • When unscrewed, pull the antenna straight up and out.
  7. Pull guide tube free from its retaining ring and slide it out the top, like the antenna (optional). The antenna and its guide tube are now removed from the phone. Congratulations.
    • Pull guide tube free from its retaining ring and slide it out the top, like the antenna (optional).
    • The antenna and its guide tube are now removed from the phone. Congratulations.
  8. Remove the four screws using a T6 Torx screwdriver.
    • Remove the four screws using a T6 Torx screwdriver.
  9. Work from the bottom of the phone, separating the two halves of the case. Note: Take care to keep the logic board with the front case half. Part of the logic board is exposed to the sticker under the battery on the rear case half.
    • Work from the bottom of the phone, separating the two halves of the case.
    • Note: Take care to keep the logic board with the front case half. Part of the logic board is exposed to the sticker under the battery on the rear case half.
  10. Angle the rear case half away from the top of the front case half, pivoting the hooks out of their clasps.
    • Angle the rear case half away from the top of the front case half, pivoting the hooks out of their clasps.
    • Caution: Do not fully separate the halves. There is an antenna ribbon connected to the logic board from the back cover.
  11. Disconnect the antenna ribbon cable from the logic board at the Zero Insertion Force (ZIF) connector. The brown portion of the connector lifts up to release the cable end. The Back Cover is now removed. Congratulations. The Back Cover is now removed. Congratulations.
    • Disconnect the antenna ribbon cable from the logic board at the Zero Insertion Force (ZIF) connector. The brown portion of the connector lifts up to release the cable end.
    • The Back Cover is now removed. Congratulations.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Brett Tomashitis
36 Reputation
5 Anleitungen geschrieben
Clemson, Team 2-6, Benson Spring 2012 Mitglied von Clemson, Team 2-6, Benson Spring 2012
CLEM-BENSON-S12S2G6
2 Mitglieder
10 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 533
