Zum Hauptinhalt wechseln
Samsung SCH-8500 Volume Button Replacement
Was du brauchst
  1. Samsung SCH-8500 Volume Button Replacement, Battery: Schritt 1, Bild 1 von 3 Samsung SCH-8500 Volume Button Replacement, Battery: Schritt 1, Bild 2 von 3 Samsung SCH-8500 Volume Button Replacement, Battery: Schritt 1, Bild 3 von 3
    • To separate the battery from the phone, use your thumb to push in the button as shown.
    • Keep the unlock button pressed as you slide the battery away from the button.
    • Pull the battery away from the phone.
  2. Samsung SCH-8500 Volume Button Replacement, Back Case: Schritt 2, Bild 1 von 3 Samsung SCH-8500 Volume Button Replacement, Back Case: Schritt 2, Bild 2 von 3 Samsung SCH-8500 Volume Button Replacement, Back Case: Schritt 2, Bild 3 von 3
    • Use a T6 Torx screwdriver to remove the highlighted screws.
    • These are the four screws, about 10 mm long, that need to be removed. Be careful with the screws as they are small and easy to misplace.
    • Carefully pry apart the two pieces, laying the back case to the side.
  3. Samsung SCH-8500 Volume Button Replacement, Volume Button: Schritt 3, Bild 1 von 3 Samsung SCH-8500 Volume Button Replacement, Volume Button: Schritt 3, Bild 2 von 3 Samsung SCH-8500 Volume Button Replacement, Volume Button: Schritt 3, Bild 3 von 3
    • With the back case fully removed and out of the way, use your fingers to remove the volume button.
    • Use caution in removal to prevent damaging any circuitry in the phone.
Abschluss
Will Gunter
1 Reputation
4 Anleitungen geschrieben
Clemson, Team 14-6, Benson Fall 2012 Mitglied von Clemson, Team 14-6, Benson Fall 2012
CLEM-BENSON-F12S14G6
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 211
