Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Ersatzteile
Keine Ersatzteile angegeben.
  1. With the phone upright and folded shut, locate the two silver tabs at the top of the screen. Using one hand, pinch the two tabs inward, and use your other hand to slide the front cover of the screen off of the phone. Note: Do not apply too much of force. If you find it difficult to remove the front cover, try pinching the tabs in harder, and make sure you are sliding the front cover directly downward.
    • With the phone upright and folded shut, locate the two silver tabs at the top of the screen.
    • Using one hand, pinch the two tabs inward, and use your other hand to slide the front cover of the screen off of the phone.
    • Note: Do not apply too much of force. If you find it difficult to remove the front cover, try pinching the tabs in harder, and make sure you are sliding the front cover directly downward.
  2. Using the T6 Torx screwdriver, remove each of the 4mm screws located in the corners of the phone. Be sure to keep track of the little screws, since they can be lost easily.
    • Using the T6 Torx screwdriver, remove each of the 4mm screws located in the corners of the phone.
    • Be sure to keep track of the little screws, since they can be lost easily.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Locate the tabs on either side of the phone. Pull the outer case away from each tab with the plastic opening tool. Locate the tabs on either side of the phone. Pull the outer case away from each tab with the plastic opening tool.
    • Locate the tabs on either side of the phone. Pull the outer case away from each tab with the plastic opening tool.
  5. Hold the phone upside-down. Two plastic tabs are located under the lip of your phone. Use a plastic opening tool to pop the outer case away from the tabs. After the outside case is clear of the four tabs, removed it.
    • Hold the phone upside-down.
    • Two plastic tabs are located under the lip of your phone. Use a plastic opening tool to pop the outer case away from the tabs.
    • After the outside case is clear of the four tabs, removed it.
Abschluss
To replace one of the screens, follow the corresponding guide from this point on. To reassemble your device, follow these instructions in reverse order.
Anthony Cisneros
1 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 11-23, Maness Winter 2012 Mitglied von Cal Poly, Team 11-23, Maness Winter 2012
CPSU-MANESS-W12S11G23
4 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 951
