Zum Hauptinhalt wechseln
Samsung SCH-A670 Keypad Housing Replacement
Was du brauchst
  1. Samsung SCH-A670 Keypad Housing Replacement, Battery Cover: Schritt 1, Bild 1 von 1
    • Slide the latch on the back of the phone up.
  2. Samsung SCH-A670 Keypad Housing Replacement, Battery: Schritt 2, Bild 1 von 1
    • Remove the battery.
  3. Samsung SCH-A670 Keypad Housing Replacement, Logic Board: Schritt 3, Bild 1 von 1
    • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
  4. Samsung SCH-A670 Keypad Housing Replacement: Schritt 4, Bild 1 von 1
    • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
  5. Samsung SCH-A670 Keypad Housing Replacement: Schritt 5, Bild 1 von 1
    • With a #0 Phillips screwdriver remove the screw which you just uncovered.
  6. Samsung SCH-A670 Keypad Housing Replacement: Schritt 6, Bild 1 von 2 Samsung SCH-A670 Keypad Housing Replacement: Schritt 6, Bild 2 von 2
    • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
    • Then disconnect the small power connector near the top of the phone.
  7. Samsung SCH-A670 Keypad Housing Replacement: Schritt 7, Bild 1 von 1
    • Gently pry up the ribbon-type connector with the spudger.
  8. Samsung SCH-A670 Keypad Housing Replacement: Schritt 8, Bild 1 von 1
    • Carefully pry the logic board from the case with the spudger.
  9. Samsung SCH-A670 Keypad Housing Replacement, Keypad: Schritt 9, Bild 1 von 1
    • Once the logic board has been removed, peel the keypad up.
  10. Samsung SCH-A670 Keypad Housing Replacement, Keypad Housing: Schritt 10, Bild 1 von 2 Samsung SCH-A670 Keypad Housing Replacement, Keypad Housing: Schritt 10, Bild 2 von 2
    • When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
Abschluss
Nathan Brink
19 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 34-59, Forte Spring 2010 Mitglied von Cal Poly, Team 34-59, Forte Spring 2010
CPSU-FORTE-S10S34G59
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,651
