Einleitung
The Keypad may get worn or dirty as time goes by. This guide will aid in the removal of the keypad for cleaning or replacement.
Was du brauchst
After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
Then disconnect the small power connector near the top of the phone.
