Einleitung
This guide will lead you through the steps necessary to gain access to the front display.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Open the device so that the inside of the phone is facing you.
Remove the small, gray, circular covers on the bottom left and right corners of the inside face of the phone.
Use the size 00 screwdriver to remove the two small screws underneath the removed covers.
Insert the spudger between the top and bottom plates to pry the cover off.
You may need to gently slide the spudger up and down to loosen the cover without snapping it.
Alternate between sides to loosen the cover more safely and effectively.
Carefully remove the cover off the device without scratching the display or harming the components.
