Zum Hauptinhalt wechseln
Samsung SCH-A950 Speakers Replacement
Was du brauchst
  1. Samsung SCH-A950 Speakers Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung SCH-A950 Speakers Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
  2. Samsung SCH-A950 Speakers Replacement, Volume and Camera Buttons: Schritt 2, Bild 1 von 1
    • Remove the four Phillips #00 screws underneath the battery.
  3. Samsung SCH-A950 Speakers Replacement: Schritt 3, Bild 1 von 2 Samsung SCH-A950 Speakers Replacement: Schritt 3, Bild 2 von 2
    • Pull open the earphone tab and the Trans Flash tab using your fingers.
  4. Samsung SCH-A950 Speakers Replacement: Schritt 4, Bild 1 von 1
    • Using a plastic opening tool, pry off the phone casing near the speakers as shown. Tabs located on the inside of the phone may make this difficult and some force may be required.
    • Slide the casing slightly forward towards the top of the phone to remove.
  5. Samsung SCH-A950 Speakers Replacement: Schritt 5, Bild 1 von 3 Samsung SCH-A950 Speakers Replacement: Schritt 5, Bild 2 von 3 Samsung SCH-A950 Speakers Replacement: Schritt 5, Bild 3 von 3
    • Using tweezers or your fingers, lift off buttons from logic board.
    • The buttons can be replaced if needed.
  6. Samsung SCH-A950 Speakers Replacement, Speakers: Schritt 6, Bild 1 von 2 Samsung SCH-A950 Speakers Replacement, Speakers: Schritt 6, Bild 2 von 2
    • Use tweezers to peel back the sticker on the backside of the speaker to reveal a screw that holds the speaker in place.
    • Using a phillips #00 screwdriver, remove the screw holding the speaker. On each side.
  7. Samsung SCH-A950 Speakers Replacement: Schritt 7, Bild 1 von 1
    • Using the tweezers, grasp the plastic connector that connects the speaker to the logic board and pull the connector off of the logic board.
  8. Samsung SCH-A950 Speakers Replacement: Schritt 8, Bild 1 von 1
    • Push the speaker out of the phone using the spudger.
  9. Samsung SCH-A950 Speakers Replacement: Schritt 9, Bild 1 von 1
    • Remove the speaker from the decorative housing by pulling on the wires.
    • The speaker can be replaced if needed.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 11-5, Forte Winter 2010 Mitglied von Cal Poly, Team 11-5, Forte Winter 2010
CPSU-FORTE-W10S11G5
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 11
Insgesamt: 1,765
