Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will teach you how remove your Samsung's SCH-A950's Volume and Camera Buttons.
  1. Slide the the battery release tab upwards while simultaneously lifting the back cover straight up. Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
    • Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
  2. Remove the four Phillips #00 screws underneath the battery.
    • Remove the four Phillips #00 screws underneath the battery.
  3. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  4. Pull open the earphone tab and the Trans Flash tab using your fingers. Pull open the earphone tab and the Trans Flash tab using your fingers.
    • Pull open the earphone tab and the Trans Flash tab using your fingers.
  5. Using a plastic opening tool, pry off the phone casing near the speakers as shown. Tabs located on the inside of the phone may make this difficult and some force may be required.
    • Using a plastic opening tool, pry off the phone casing near the speakers as shown. Tabs located on the inside of the phone may make this difficult and some force may be required.
    • Slide the casing slightly forward towards the top of the phone to remove.
  6. Using tweezers or your fingers, lift off buttons from logic board. The buttons can be replaced if needed. The buttons can be replaced if needed.
    • Using tweezers or your fingers, lift off buttons from logic board.
    • The buttons can be replaced if needed.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Sean Kennedy
49 Reputation
1 Anleitung geschrieben
Cal Poly, Team 11-5, Forte Winter 2010 Mitglied von Cal Poly, Team 11-5, Forte Winter 2010
CPSU-FORTE-W10S11G5
5 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 1,769
