Zum Hauptinhalt wechseln
Samsung SCH-U340 Internal Antenna Replacement
Was du brauchst
  1. Samsung SCH-U340 Internal Antenna Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the cell phone so that the back side is facing you.
    • Press the upper indent and slide the back cover down.
  2. Samsung SCH-U340 Internal Antenna Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery up from indent at the bottom and slide it out.
  3. Samsung SCH-U340 Internal Antenna Replacement: Schritt 3, Bild 1 von 1
    • Set the battery aside.
  4. Samsung SCH-U340 Internal Antenna Replacement, Lower Casing: Schritt 4, Bild 1 von 1
    • The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
  5. Samsung SCH-U340 Internal Antenna Replacement: Schritt 5, Bild 1 von 2 Samsung SCH-U340 Internal Antenna Replacement: Schritt 5, Bild 2 von 2
    • Use a spudger to pry the back assembly off of the device.
  6. Samsung SCH-U340 Internal Antenna Replacement, Internal Antenna: Schritt 6, Bild 1 von 1
    • On the bottom casing, there should be a single metal screw holding the antennae in. Remove this screw.
  7. Samsung SCH-U340 Internal Antenna Replacement: Schritt 7, Bild 1 von 2 Samsung SCH-U340 Internal Antenna Replacement: Schritt 7, Bild 2 von 2
    • Pry the antennae off by inserting a flat object such as a spudgel into the slot marked in yellow and pushing upwards.
Abschluss
David Gomez
1 Reputation
1 Anleitung geschrieben
Cal Poly, Team 3-21, Maness Winter 2010 Mitglied von Cal Poly, Team 3-21, Maness Winter 2010
CPSU-MANESS-W10S3G21
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 3,236
