Einleitung
Use this guide to remove the logic board assembly from the casing.
Was du brauchst
Turn the cell phone so that the back side is facing you.
Press the upper indent and slide the back cover down.
The outer casing consists of two separate parts on the upper and lower halves of the device. The upper outer casing is held on through a combination of screws and tabs.
First, remove the plastic plugs covering the screws with a spudger.
Underneath the plugs are two small screws that can be removed with a small Phillips screwdriver.
The outer cover is now secured with seven tabs: one large tab (marked in red) and seven smaller tabs (marked in orange).
To begin removing the outer cover, start by prying the large tab up with a flat object.
See next slide for details for smaller tabs.
The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
Rotate the logic board assembly out of the casing, being careful not to break VGA cable.
