Einleitung
This guide will cover the removal of the Samsung SCH-U340 top casing.
Was du brauchst
Turn the cell phone so that the back side is facing you.
Press the upper indent and slide the back cover down.
The outer casing consists of two separate parts on the upper and lower halves of the device. The upper outer casing is held on through a combination of screws and tabs.
First, remove the plastic plugs covering the screws with a spudger.
Underneath the plugs are two small screws that can be removed with a small Phillips screwdriver.
The outer cover is now secured with seven tabs: one large tab (marked in red) and seven smaller tabs (marked in orange).
To begin removing the outer cover, start by prying the large tab up with a flat object.
See next slide for details for smaller tabs.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
