Einleitung
The replacement of this flash light bulb will be needed when flash mode isn't working.
Was du brauchst
Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
Remove the corner panel by applying pressure away from the shutter button.
Remove the top panel by applying gentle pressure away from the shutter button.
Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
Remove the screw securing the shutter button to the camera frame.
Lift the shutter button to remove it.
Remove the screws from the circuitry with a Phillips #000 driver.
Remove the screw connecting the flash housing to the camera frame with the same driver.
Pull the flash housing away from the camera frame.
Cut the wires connecting the flash module to the circuitry.
Connect the new flash module to the circuitry with a soldering iron and electrical solder.
