Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Is your flash weak or not working at all? It could be your flash capacitor. Here's a replacement guide to help.
  1. Unscrew all visible screws indicated by red circles with a #00 Phillips driver. Slide memory card cover and unscrew hidden screw  underneath with a #00 Phillips driver. Slide memory card cover and unscrew hidden screw  underneath with a #00 Phillips driver.
    • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
    • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
  2. Remove the flat side panel by applying gentle pressure toward the bottom of the camera. Remove the corner panel by applying pressure away from the shutter button. The memory card cover will come off with the corner panel.
    • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
    • Remove the corner panel by applying pressure away from the shutter button.
    • The memory card cover will come off with the corner panel.
    • Remove the top panel by applying gentle pressure away from the shutter button.
  3. Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
    • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  4. Essential Electronics Toolkit
    Kompakte Alleskönner.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  5. Remove the front and back covers by pulling them straight apart. Remove the front and back covers by pulling them straight apart.
    • Remove the front and back covers by pulling them straight apart.
  6. Remove the screw securing the shutter button. Lift the shutter button to remove it.
    • Remove the screw securing the shutter button.
    • Lift the shutter button to remove it.
  7. Remove the 3 visible screws with a Phillips #000 Driver Move the circuitry and wires out of the way to expose another screw, and remove it with the same driver.
    • Remove the 3 visible screws with a Phillips #000 Driver
    • Move the circuitry and wires out of the way to expose another screw, and remove it with the same driver.
  8. Pull the flash capacitor out of its compartment to expose the wires connected to it. Cut the connecting wires with wire cutters. Solder the wires to the new power source with a soldering iron and electrical solder.
    • Pull the flash capacitor out of its compartment to expose the wires connected to it.
    • Cut the connecting wires with wire cutters.
    • Solder the wires to the new power source with a soldering iron and electrical solder.
Abschluss
Evert Jordan
281 Reputation
2 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 63
