Einleitung
Is your screen broken or faulty? This guide will help you replace it.
Was du brauchst
Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
Remove the corner panel by applying pressure away from the shutter button.
Remove the top panel by applying gentle pressure away from the shutter button.
Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
Open the ribbon connector with your fingernail.
Pull the ribbon out of the connection.
Pull the ribbon connected to the screen out from behind the button circuitry on the rear of the camera.
Feed the new screen's ribbon through the same slot it came out of.
