Einleitung
The motherboard of this flip phone can become faulty for no reason at all, other then just becoming old over time. Sometimes, dirt and debris can creep its way under the motherboard causing it to malfunction. The process of replacing the motherboard is not too challenging but does require patience and focus.
Was du brauchst
Remove the battery by pressing the battery lock down and slide the battery cover away.
Locate the 4 screws holes on the phone and remove them with the #000 Philips Head screwdriver. (See red circles)
Simply flick the rectangular connector up from its socket. (Highlighted by the red square)
2 weitere Nutzer:innen haben diese Anleitung absolviert.
