Zum Hauptinhalt wechseln
Samsung SGH-A137 Motherboard Replacement
Was du brauchst
  1. Samsung SGH-A137 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use your thumbs to pull down on the back cover to remove it and expose the battery.
  2. Samsung SGH-A137 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Locate the indent in the case below the battery. (see red square)
    • Place your finger at the indent and pull up on the battery to remove it.
  3. Samsung SGH-A137 Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 3 Samsung SGH-A137 Motherboard Replacement, Motherboard: Schritt 3, Bild 2 von 3 Samsung SGH-A137 Motherboard Replacement, Motherboard: Schritt 3, Bild 3 von 3
    • Locate the 4 screw holes and remove the 0.4 mm Phillips head screws using a #000 Phillips head screwdriver. (See red circles)
  4. Samsung SGH-A137 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Using a plastic opening tool, gently pry open the back of the phone at the seam.
    • Carefully work the tool all the way around the opening while prying up to avoid breaking the plastic retaining clips.
  5. Samsung SGH-A137 Motherboard Replacement: Schritt 5, Bild 1 von 2 Samsung SGH-A137 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Smaller press-fit connectors may require a simple flick with a plastic opening tool or spudger.
    • Place the flat edge of a spudger under the edge of the press-fit connector and , gently pry the connector straight up from its socket. (Highlighted by the red square)
  6. Samsung SGH-A137 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Using a plastic opening tool, gently pry up the motherboard.
    • You might need to pry from several different locations to get the motherboard loose enough to remove.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015 Mitglied von USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015
USFSM-STEWART-F15S1G1
5 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 546
