Zum Hauptinhalt wechseln
Samsung SGH-A237 Logic Board Replacement
Was du brauchst
  1. Samsung SGH-A237 Logic Board Replacement, Logic Board: Schritt 1, Bild 1 von 2 Samsung SGH-A237 Logic Board Replacement, Logic Board: Schritt 1, Bild 2 von 2
    • Put the phone face down so that the battery cover is showing.
  2. Samsung SGH-A237 Logic Board Replacement: Schritt 2, Bild 1 von 2 Samsung SGH-A237 Logic Board Replacement: Schritt 2, Bild 2 von 2
    • Use your thumb to push the cover down and off.
    • Lift the battery off the device.
  3. Samsung SGH-A237 Logic Board Replacement: Schritt 3, Bild 1 von 2 Samsung SGH-A237 Logic Board Replacement: Schritt 3, Bild 2 von 2
    • Remove the five screws with a size 00 screwdriver. There 4 in the corners and one on the top as shown.
  4. Samsung SGH-A237 Logic Board Replacement: Schritt 4, Bild 1 von 3 Samsung SGH-A237 Logic Board Replacement: Schritt 4, Bild 2 von 3 Samsung SGH-A237 Logic Board Replacement: Schritt 4, Bild 3 von 3
    • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Note: some force must be applied when removing back cover.
  5. Samsung SGH-A237 Logic Board Replacement: Schritt 5, Bild 1 von 1
    • Detach the tab from the logic board by using iPod Opening Tool (as shown).
  6. Samsung SGH-A237 Logic Board Replacement: Schritt 6, Bild 1 von 2 Samsung SGH-A237 Logic Board Replacement: Schritt 6, Bild 2 von 2
    • Use iPod Opening Tool to lift the green logic board carefully.
    • Remove logic board from the device and replace with new one.
Abschluss
Cal Poly, Team 29-81, Johann Spring 2010 Mitglied von Cal Poly, Team 29-81, Johann Spring 2010
CPSU-JOHANN-S10S29G81
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 2,805
