Zum Hauptinhalt wechseln
Samsung SGH-E317 Motherboard Replacement
Was du brauchst
  1. Samsung SGH-E317 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • You may want to use a plastic opening tool to help pry the back panel off.
  2. Samsung SGH-E317 Motherboard Replacement, Motherboard: Schritt 2, Bild 1 von 1
    • Unscrew the four 4.5mm screws located on the back plate.
  3. Samsung SGH-E317 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the rubber screw cover using your fingernail.
  4. Samsung SGH-E317 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the 4.5mm screw located underneath the rubber cover.
  5. Samsung SGH-E317 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
    • The panel should come off without much effort.
  6. Samsung SGH-E317 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • With the back panel removed, the motherboard should be fully exposed.
  7. Samsung SGH-E317 Motherboard Replacement: Schritt 7, Bild 1 von 2 Samsung SGH-E317 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Remove the camera and volume buttons and place them in a safe spot until reassembly.
  8. Samsung SGH-E317 Motherboard Replacement: Schritt 8, Bild 1 von 2 Samsung SGH-E317 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
  9. Samsung SGH-E317 Motherboard Replacement: Schritt 9, Bild 1 von 2 Samsung SGH-E317 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
Abschluss
Cal Poly, Team 11-23, Maness Winter 2011 Mitglied von Cal Poly, Team 11-23, Maness Winter 2011
CPSU-MANESS-W11S11G23
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 1,382
