Einleitung
The motherboard is the main electronic "heart" of the phone. Only proceed with this replacement if you have tried all other options to no avail.
Was du brauchst
Remove the back panel by pressing up on switch, located at the top on the back of the phone.
Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
Remove the camera and volume buttons and place them in a safe spot until reassembly.
Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
