Zum Hauptinhalt wechseln
Samsung SGH-T639 Screen Replacement
Was du brauchst
  1. Samsung SGH-T639 Screen Replacement, Screen: Schritt 1, Bild 1 von 3 Samsung SGH-T639 Screen Replacement, Screen: Schritt 1, Bild 2 von 3 Samsung SGH-T639 Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Flip phone over and locate the screw covers.
    • Remove the two thin screw covers using the tweezers.
  2. Samsung SGH-T639 Screen Replacement: Schritt 2, Bild 1 von 3 Samsung SGH-T639 Screen Replacement: Schritt 2, Bild 2 von 3 Samsung SGH-T639 Screen Replacement: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    Kaufen
    • Locate the two screws (3mm) at the base of the top portion of the cell phone.
    • Remove screws using a phillips head #000 screwdriver.
    • Place screws on magnetic mat.
  3. Samsung SGH-T639 Screen Replacement: Schritt 3, Bild 1 von 2 Samsung SGH-T639 Screen Replacement: Schritt 3, Bild 2 von 2
    • Locate the seam of the casing along the edge of the phone.
    • Starting at the end, gently begin to pry the front casing away from the phone. Use the plastic opening tool for this step.
  4. Samsung SGH-T639 Screen Replacement: Schritt 4, Bild 1 von 3 Samsung SGH-T639 Screen Replacement: Schritt 4, Bild 2 von 3 Samsung SGH-T639 Screen Replacement: Schritt 4, Bild 3 von 3
    • Continue to pry the casing from the front of the cell phone.
    • Remove front casing from the cell phone.
  5. Samsung SGH-T639 Screen Replacement: Schritt 5, Bild 1 von 3 Samsung SGH-T639 Screen Replacement: Schritt 5, Bild 2 von 3 Samsung SGH-T639 Screen Replacement: Schritt 5, Bild 3 von 3
    • Locate the small battery at the end of the cell phone.
    • Gently remove the battery from the cell phone using tweezers.
    • Note: This may require some force.
    • Do not disconnect the battery from the entire phone. Simply lift the battery from the cell phone while keeping the wires connected.
  6. Samsung SGH-T639 Screen Replacement: Schritt 6, Bild 1 von 3 Samsung SGH-T639 Screen Replacement: Schritt 6, Bild 2 von 3 Samsung SGH-T639 Screen Replacement: Schritt 6, Bild 3 von 3
    • Locate the speaker at the end of the cell phone.
    • Gently grasp and lift the speaker from the cell phone using tweezers.
    • Do not disconnect the speaker from the entire cell phone. Simply lift the speaker while leaving the wires connected.
  7. Samsung SGH-T639 Screen Replacement: Schritt 7, Bild 1 von 3 Samsung SGH-T639 Screen Replacement: Schritt 7, Bild 2 von 3 Samsung SGH-T639 Screen Replacement: Schritt 7, Bild 3 von 3
    • Locate the tip of the sheer protection film.
    • Gently lift and remove the protection film with tweezers.
  8. Samsung SGH-T639 Screen Replacement: Schritt 8, Bild 1 von 3 Samsung SGH-T639 Screen Replacement: Schritt 8, Bild 2 von 3 Samsung SGH-T639 Screen Replacement: Schritt 8, Bild 3 von 3
    • Locate the top tabs of the screen and circuit board unit
    • Gently lift the screen and circuit board as one unit from the cell phone using the tweezers.
    • Make sure the screen and circuit board are removed as one unit. Do not disconnect the screen from the circuit board.
  9. Samsung SGH-T639 Screen Replacement: Schritt 9, Bild 1 von 3 Samsung SGH-T639 Screen Replacement: Schritt 9, Bild 2 von 3 Samsung SGH-T639 Screen Replacement: Schritt 9, Bild 3 von 3
    • Locate the gold connector that is attached to the circuit board.
    • Pull the connection away from the circuit board.
  10. Samsung SGH-T639 Screen Replacement: Schritt 10, Bild 1 von 1
    • Completely remove the screen and circuit board unit from the cell phone.
Abschluss
Yi Ren
801 Reputation
8 Anleitungen geschrieben
Clemson, Team 1-4, Benson Spring 2014 Mitglied von Clemson, Team 1-4, Benson Spring 2014
CLEM-BENSON-S14S1G4
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 361
