Zum Hauptinhalt wechseln
Samsung SGH-T639 Volumn Button Replacement
Was du brauchst
  1. Samsung SGH-T639 Volumn Button Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the phone over and take off the back cover
    • Note: These images do not contain the back cover or battery of the phone.
  2. Samsung SGH-T639 Volumn Button Replacement: Schritt 2, Bild 1 von 1
    • Use button to remove battery from the phone.
  3. Samsung SGH-T639 Volumn Button Replacement, SIM Card: Schritt 3, Bild 1 von 3 Samsung SGH-T639 Volumn Button Replacement, SIM Card: Schritt 3, Bild 2 von 3 Samsung SGH-T639 Volumn Button Replacement, SIM Card: Schritt 3, Bild 3 von 3
    • Locate SIM card
    • Slide SIM card down and gently pull out of the card slot
  4. Samsung SGH-T639 Volumn Button Replacement, Volumn Button: Schritt 4, Bild 1 von 3 Samsung SGH-T639 Volumn Button Replacement, Volumn Button: Schritt 4, Bild 2 von 3 Samsung SGH-T639 Volumn Button Replacement, Volumn Button: Schritt 4, Bild 3 von 3
    • Locate the six (4mm) screws on the back of the phone.
    • Unscrew all six screws using a Phillips head #000 screwdriver.
  5. Samsung SGH-T639 Volumn Button Replacement: Schritt 5, Bild 1 von 3 Samsung SGH-T639 Volumn Button Replacement: Schritt 5, Bild 2 von 3 Samsung SGH-T639 Volumn Button Replacement: Schritt 5, Bild 3 von 3
    • Locate volume button.
    • Starting at the top, pry the back casing of the phone.
    • Continue prying around the side of the phone. Being careful around the volume button.
  6. Samsung SGH-T639 Volumn Button Replacement: Schritt 6, Bild 1 von 3 Samsung SGH-T639 Volumn Button Replacement: Schritt 6, Bild 2 von 3 Samsung SGH-T639 Volumn Button Replacement: Schritt 6, Bild 3 von 3
    • Remove back casing from the phone.
    • Relocate the volume button.
    • Gently push the volume button towards the interior of the back casing of the phone.
  7. Samsung SGH-T639 Volumn Button Replacement: Schritt 7, Bild 1 von 1
    • Completely remove the volume button from the cell phone.
Abschluss
Yi Ren
801 Reputation
8 Anleitungen geschrieben
Clemson, Team 1-4, Benson Spring 2014 Mitglied von Clemson, Team 1-4, Benson Spring 2014
CLEM-BENSON-S14S1G4
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 163
