Zum Hauptinhalt wechseln
Samsung SGH-X105 Keypad Replacement
Was du brauchst
  1. Samsung SGH-X105 Keypad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Rotate the phone onto its front side so that the LCD screen is facing away from you.
  2. Samsung SGH-X105 Keypad Replacement: Schritt 2, Bild 1 von 3 Samsung SGH-X105 Keypad Replacement: Schritt 2, Bild 2 von 3 Samsung SGH-X105 Keypad Replacement: Schritt 2, Bild 3 von 3
    • Remove the battery by pressing down on the battery release button while sliding the battery downwards.
  3. Samsung SGH-X105 Keypad Replacement, Front & Back Panels: Schritt 3, Bild 1 von 1
    • Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
    • Complete removal of screws may not be necessary.
  4. Samsung SGH-X105 Keypad Replacement: Schritt 4, Bild 1 von 3 Samsung SGH-X105 Keypad Replacement: Schritt 4, Bild 2 von 3 Samsung SGH-X105 Keypad Replacement: Schritt 4, Bild 3 von 3
    • Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
    • Volume control button will be unsecured and may fall out as soon as the panels are separated.
    • Gentle force may be required to separate the panels at the top latch.
    • There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
  5. Samsung SGH-X105 Keypad Replacement: Schritt 5, Bild 1 von 2 Samsung SGH-X105 Keypad Replacement: Schritt 5, Bild 2 von 2
    • Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
  6. Samsung SGH-X105 Keypad Replacement, Keypad: Schritt 6, Bild 1 von 1
    • Put aside the back panel. You will only be working with the front panel from here on.
  7. Samsung SGH-X105 Keypad Replacement: Schritt 7, Bild 1 von 2 Samsung SGH-X105 Keypad Replacement: Schritt 7, Bild 2 von 2
    • Take out the key pad by pressing the keys on the face of the phone and pulling the rubber keypad from the other side.
Abschluss
Cal Poly, Team 28-29, Regan Spring 2010 Mitglied von Cal Poly, Team 28-29, Regan Spring 2010
CPSU-REGAN-S10S28G29
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,259
