Zum Hauptinhalt wechseln
Samsung SGH-X105 Loud Speaker Replacement
Was du brauchst
  1. Samsung SGH-X105 Loud Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Rotate the phone onto its front side so that the LCD screen is facing away from you.
  2. Samsung SGH-X105 Loud Speaker Replacement: Schritt 2, Bild 1 von 3 Samsung SGH-X105 Loud Speaker Replacement: Schritt 2, Bild 2 von 3 Samsung SGH-X105 Loud Speaker Replacement: Schritt 2, Bild 3 von 3
    • Remove the battery by pressing down on the battery release button while sliding the battery downwards.
  3. Samsung SGH-X105 Loud Speaker Replacement, Front & Back Panels: Schritt 3, Bild 1 von 1
    • Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
    • Complete removal of screws may not be necessary.
  4. Samsung SGH-X105 Loud Speaker Replacement: Schritt 4, Bild 1 von 3 Samsung SGH-X105 Loud Speaker Replacement: Schritt 4, Bild 2 von 3 Samsung SGH-X105 Loud Speaker Replacement: Schritt 4, Bild 3 von 3
    • Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
    • Volume control button will be unsecured and may fall out as soon as the panels are separated.
    • Gentle force may be required to separate the panels at the top latch.
    • There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
  5. Samsung SGH-X105 Loud Speaker Replacement: Schritt 5, Bild 1 von 2 Samsung SGH-X105 Loud Speaker Replacement: Schritt 5, Bild 2 von 2
    • Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
  6. Samsung SGH-X105 Loud Speaker Replacement, Logic Board: Schritt 6, Bild 1 von 3 Samsung SGH-X105 Loud Speaker Replacement, Logic Board: Schritt 6, Bild 2 von 3 Samsung SGH-X105 Loud Speaker Replacement, Logic Board: Schritt 6, Bild 3 von 3
    • Gently remove the logic board and LCD screen from the back cover of the phone.
  7. Samsung SGH-X105 Loud Speaker Replacement: Schritt 7, Bild 1 von 1
    • Remove the two screws above the LCD screen with a Phillips #00 screw driver. These connect to the white plastic cover in which the speaker is housed located on the reverse side of the logic board.
    • Make sure the white plastic cover remains in contact with the logic board while removing the screws.
  8. Samsung SGH-X105 Loud Speaker Replacement: Schritt 8, Bild 1 von 3 Samsung SGH-X105 Loud Speaker Replacement: Schritt 8, Bild 2 von 3 Samsung SGH-X105 Loud Speaker Replacement: Schritt 8, Bild 3 von 3
    • Rotate the logic board so that the LCD screen is face down.
    • Make sure the white plastic cover remains in contact with the logic board while it is being rotated.
    • Screws may fall out as the object is rotated.
  9. Samsung SGH-X105 Loud Speaker Replacement: Schritt 9, Bild 1 von 2 Samsung SGH-X105 Loud Speaker Replacement: Schritt 9, Bild 2 von 2
    • Gently begin to separate the white plastic cover from the logic board.
    • This cover will be connected by two small wires. Be sure not to break this connection.
  10. Samsung SGH-X105 Loud Speaker Replacement: Schritt 10, Bild 1 von 2 Samsung SGH-X105 Loud Speaker Replacement: Schritt 10, Bild 2 von 2
    • Locate the two wires (black and red) which connect the speaker to the logic board.
    • Using your nails, tweezers, or any precise grabbing tool, pinch the speaker connector (clear plastic plug that goes into the logic board) and pull gently. It should pop out easily.
    • Once the wires are disconnected and the screws removed, the white plastic cover can easily be removed from the logic board.
  11. Samsung SGH-X105 Loud Speaker Replacement, Loud Speaker: Schritt 11, Bild 1 von 3 Samsung SGH-X105 Loud Speaker Replacement, Loud Speaker: Schritt 11, Bild 2 von 3 Samsung SGH-X105 Loud Speaker Replacement, Loud Speaker: Schritt 11, Bild 3 von 3
    • Use any small flat object to remove the speaker from the white plastic cover by wedging your tool between the speaker and the cover.
    • The speaker is attached by an adhesive so gently pry the speaker from the cover.
Abschluss
Cal Poly, Team 28-29, Regan Spring 2010 Mitglied von Cal Poly, Team 28-29, Regan Spring 2010
CPSU-REGAN-S10S28G29
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,746
