Zum Hauptinhalt wechseln
Samsung SGH-X495 Backplate Replacement
Was du brauchst
  1. Samsung SGH-X495 Backplate Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung SGH-X495 Backplate Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use thumb nail to release the white hook; then use fingertip to pry the battery loose starting from the top.
    • Second photo gives a view from the back of the phone and battery.
  2. Samsung SGH-X495 Backplate Replacement, Backplate: Schritt 2, Bild 1 von 1
    • Remove the 4 (4.7mm) philips head screws.
  3. Samsung SGH-X495 Backplate Replacement: Schritt 3, Bild 1 von 1
    • Unplug the rubber charger outlet cover.
  4. Samsung SGH-X495 Backplate Replacement: Schritt 4, Bild 1 von 1
    • Unplug the rubber headset jack cover.
  5. Samsung SGH-X495 Backplate Replacement: Schritt 5, Bild 1 von 2 Samsung SGH-X495 Backplate Replacement: Schritt 5, Bild 2 von 2
    • Begin by inserting the pry tool near the charger jack.
    • There are 4 tabs to release.
    • Start at the bottom and slide the tool up, lifting the silver front of the phone away from the white backing.
    • Loosen the 2 side tabs before moving on to the top two.
    • See the second photo to see location of the tabs.
    • Be careful of the ribbon wires shown in second photo.
  6. Samsung SGH-X495 Backplate Replacement: Schritt 6, Bild 1 von 2 Samsung SGH-X495 Backplate Replacement: Schritt 6, Bild 2 von 2
    • Once the two side tabs are free; gently pry the white backing down to release the top two tabs.
    • Hold the phone with the left hand as shown
    • Wiggle the white backplate from side to side while pulling down with the right hand.
Abschluss
Matthew Hove
1.031 Reputation
10 Anleitungen geschrieben
Cal Poly, Team 3-40, Regan Winter 2011 Mitglied von Cal Poly, Team 3-40, Regan Winter 2011
CPSU-REGAN-W11S3G40
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 1,262
