Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the 4 (4.7mm) philips head screws.
    • Remove the 4 (4.7mm) philips head screws.
  2. Unplug the rubber charger outlet cover.
    • Unplug the rubber charger outlet cover.
  3. Unplug the rubber headset jack cover.
    • Unplug the rubber headset jack cover.
  4. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Begin by inserting the pry tool near the charger jack. There are 4 tabs to release.
    • Begin by inserting the pry tool near the charger jack.
    • There are 4 tabs to release.
      • Start at the bottom and slide the tool up, lifting the silver front of the phone away from the white backing.
    • Loosen the 2 side tabs before moving on to the top two.
    • See the second photo to see location of the tabs.
    • Be careful of the ribbon wires shown in second photo.
  6. Once the two side tabs are free; gently pry the white backing down to release the top two tabs. Hold the phone with the left hand as shown
    • Once the two side tabs are free; gently pry the white backing down to release the top two tabs.
    • Hold the phone with the left hand as shown
    • Wiggle the white backplate from side to side while pulling down with the right hand.
  7. Remove the ribbon wires connecting to the screen using the pry tool.
    • Remove the ribbon wires connecting to the screen using the pry tool.
  8. 2 tabs hold the motherboard in place.
    • 2 tabs hold the motherboard in place.
    • Release the labeled tabs with the pry tool from the location shown.
  9. Separate the motherboard from the phone.
    • Separate the motherboard from the phone.
  10. Solder connections can be accessed to replace head phone jack.
    • Solder connections can be accessed to replace head phone jack.
Abschluss
Matthew Hove
1.031 Reputation
10 Anleitungen geschrieben
Cal Poly, Team 3-40, Regan Winter 2011 Mitglied von Cal Poly, Team 3-40, Regan Winter 2011
CPSU-REGAN-W11S3G40
4 Mitglieder
20 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,589
