Zum Hauptinhalt wechseln
Samsung SPH-A500 Front LCD Display Replacement
Was du brauchst
  1. Samsung SPH-A500 Front LCD Display Replacement, Front LCD Display: Schritt 1, Bild 1 von 1
    • Flip open the phone, remove the two rubber covers under the LCD screen.
    • Remove the two screws using a small Philips screwdriver.
  2. Samsung SPH-A500 Front LCD Display Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic opening tool, pry open the back cover of the LCD screen.
    • Note: Some force may be required.
  3. Samsung SPH-A500 Front LCD Display Replacement: Schritt 3, Bild 1 von 1
    • Completely separate the back cover from the rest of the phone.
    • Close the phone.
  4. Samsung SPH-A500 Front LCD Display Replacement: Schritt 4, Bild 1 von 1
    • The LCD screen is big, rectangular screen in the center of the logic board.
  5. Samsung SPH-A500 Front LCD Display Replacement: Schritt 5, Bild 1 von 1
    • Remove the glue and black tape that is attached to the LCD screen
  6. Samsung SPH-A500 Front LCD Display Replacement: Schritt 6, Bild 1 von 1
    • Remove Broken LCD Screen.
  7. Samsung SPH-A500 Front LCD Display Replacement: Schritt 7, Bild 1 von 1
    • Attach the New LCD Screen, with wire point up and out to the black connector.
    • Note: Super Glue may be required to permanently attach LCD to the black connector
Abschluss
Cal Poly, Team 18-100, Johann Spring 2010 Mitglied von Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 13
Insgesamt: 2,501
