Einleitung
Repair guide on how to replace the keypad in a Samsung SPH-A500.
  1. Turn phone over
    • Turn phone over
    • Push the gray tab above the battery forward to remove the battery.
  2. Remove the battery from the phone, which will reveal four screws at the corners of the phone.
    • Remove the battery from the phone, which will reveal four screws at the corners of the phone.
  3. Remove all four screws using a small Philips screwdriver.
    • Remove all four screws using a small Philips screwdriver.
    • Note: The screws do not need to be completely removed from the case, as long as they are unscrewed.
  4. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Remove back cover by carefully prying it open.
    • Remove back cover by carefully prying it open.
    • Note: Some force may be required.
  6. Pull the side tabs outward while simultaneously lifting up the circuit board.
    • Pull the side tabs outward while simultaneously lifting up the circuit board.
  7. Lift circuit board from the bottom of the phone.
    • Lift circuit board from the bottom of the phone.
    • WARNING: DO NOT completely remove circuit board from the phone, since it is still attached at the top of the phone.
  8. Flip the circuit board around the top of the phone.
    • Flip the circuit board around the top of the phone.
    • Lift the rubber keypad off.
  9. Replace the keypad.
    • Replace the keypad.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Nick Dominikovic
139 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 18-100, Johann Spring 2010 Mitglied von Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Mitglieder
10 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,685
