Zum Hauptinhalt wechseln
Einleitung
This is a step by step guide on how to replace the Samsung SPH-A500 logic board.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn phone over
    • Turn phone over
    • Push the gray tab above the battery forward to remove the battery.
  2. Remove the battery from the phone, which will reveal four screws at the corners of the phone.
    • Remove the battery from the phone, which will reveal four screws at the corners of the phone.
  3. Remove all four screws using a small Philips screwdriver.
    • Remove all four screws using a small Philips screwdriver.
    • Note: The screws do not need to be completely removed from the case, as long as they are unscrewed.
  4. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  5. Remove back cover by carefully prying it open.
    • Remove back cover by carefully prying it open.
    • Note: Some force may be required.
  6. Pull the side tabs outward while simultaneously lifting up the circuit board.
    • Pull the side tabs outward while simultaneously lifting up the circuit board.
    • Do not completely pull out the circuit board.
  7. Look for the clip at the top right corner of the logic board.
    • Look for the clip at the top right corner of the logic board.
  8. Remove the clip from the logic board.
    • Remove the clip from the logic board.
  9. Remove the logic board.
    • Remove the logic board.
    • Replace the broken logic board with a new one.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Nick Dominikovic
139 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 18-100, Johann Spring 2010 Mitglied von Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
Insgesamt: 1,890
