Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Will your phone not turn on even after you have it plugged in? You may have a faulty battery. Follow these steps to replace it.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn the phone over so that it is face down. Turn the phone over so that it is face down.
    • Turn the phone over so that it is face down.
  2. To remove the battery, push up with your finger on the tab located on the top center of the back of the phone. Next, pull the battery off the back of the phone. Next, pull the battery off the back of the phone.
    • To remove the battery, push up with your finger on the tab located on the top center of the back of the phone.
    • Next, pull the battery off the back of the phone.
Abschluss
Mike Buerli
4 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 13-26, Maness Winter 2010 Mitglied von Cal Poly, Team 13-26, Maness Winter 2010
CPSU-MANESS-W10S13G26
3 Mitglieder
9 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 2,705
