Einleitung
This guide shows how to replace the speakers of your Samsung SPH-A760 phone.
Was du brauchst
Push open the latch and remove the battery.
Twist off the antenna.
Pop off the transparent cylinder.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Pop out the logic board with spudger.
Remove the hinge on the phone.
Put pressure on the spring with the screwdriver to unhinge phone.
Make sure to pull the gold wire through, don't let it rip.
Remove the four screws as shown
Use the spudger to pry it open, excessive force may be necessary.
